Air intake manifold design
91-GS
1,390
66
Jan 12, 2013
Paris, Tennessee
Have never seen a plenum attached this way, don't know enough to say why not. Would like to discuss this design.
In my oppinion this will provide adjustability to plenum volume as well as runner lenth (plenum might bey made up of two parts, one sliding over another, as well as runners being made same way on the part that attaches to the plenum). Also due to the flow-through design, the air would be getting into runners alot easier since it does not have to make a 90 degree turn like in conventional desigs.
Would like your oppinions about it.
Wouldnt that place the plenum right on the battery and the throttlebody/IC piping on the strut tower?
Reminds me of an exhaust manni.
It would, but this is just a rough draft that can be tweaked and moved around some. I got inspired to do this after looking at some exhaust headers, that's probably why.
What exactly are you talking about?
EDIT: Oh, never mind. I see what part you are talking about. Still, it's inside a smooth pipe, not trying to go over an edge like in stock intakes?
Sorry not trying to bash it just my opinion. Would you use this on a naturaly aspirated motor? As opposed to the "header" manifold sees vacuum, so I dont see how it can benefit fron a "smotther" pipe.
It's ok, Kid. I want some critisism so to know what needs improvement :thumb:
This was planned for a non-turbo motor. Please explain the "manifold sees vacuum" part. Did you mean "uses vacuum"?
That type of manifold would be beneficial for low end torque. The long runners and sweeping bends will give the air lots of velocity but in the higher rpms will choke out. That manifold looks a lot like a late 90s toyota 1.8l intake.
If such a design were to be engineered for a turbo engine, I think it'd fail since shorter runners are better. Still not bad bad for thinking outside the box to develop something new.
TurboAnything, thanks for the picture, had no idea something similar was built. Where's the plenum on that thing? Does it bolt on to this header?
Spyderdrifter, the runners in the design are approximatly 12" long (when measuring center line of each runner). That's the same as stock n/t ones, tuned for lower end torque, about 6000 RPM peak.
Any advice on plenum volume? And how it affects engine perfomance?
GM also used a similar intake manifold on their Quad-4 engine from the late 80s to the early 90s. Don't think it is gonna work to well without a lot of modding. May be worth looking into though. If the runner spacing is close enough you might be able to cut the GM flange off and have a DSM flange welded on. Just a thought.
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
