Hx35 help
ty92dsm
189
Dec 15, 2010
columbus, Ohio
Ok so I'm running the FP manifold and im having some fitment issues with the hx35. I have already cleared the water pipe but the compressor outlet points straight into the front motor mount. I'm wondering if anyone else has ran into this problem and what was the solution? I would post a picture but my damn iPhone won't let me
Yea it'll work, make sure you add the coupler and your fmic piping before bolting everything on just so you know that the fitment is good.
Got any pictures of fitment before and after clocking the compressor housing? I'd like to go to them for reference when I install mine this summer. Thanks
Rotate the compressor housing till it clears.. That's what I did on mine.
I have the exact same setup as the OP and this worked 100% for me. However, you *may* run into issues with the oil drain; see HERE for help on that.
If this is in reference to the oil drain problem, my calibrated eyeball tells me I'd have to remove more of the mount than I would be comfortable with to get the fitting to clear.
Would you mind posting a picture of how much you took out?
Yea I know, but I didn't mean to rotate the turbo by loosening the exhaust side. You can rotate the compressor cover without messing up on how the oil is gonna drain.
Sorry for any confusion; but the issue I was describing was with the oild at 12 and 6; just wanted to give the OP a heads up.
