HX35 Failure
jperks911
4
Mar 30, 2022
Ashby, Massachusetts
Hey guys, I'm trying to pin point what caused this type of failure. It happened during a etune. Doing a small pull during the tune, i heard a small pop and then smoke. I just assumed the turbo seals failed. I finally took it apart this week as a bought a new cartridge. Took the turbo out and i found the hot side of the turbo es completely desimated and the housing destroyed. I've attached the pictures of the hx35 turbo and the housing. Thanks in advance!
Holsets need a 3/4 drain. Although I doubt that's what caused it to grenade like that.
Was it an original off a truck or did someone rebuild it?
It was probably an original. I bought it used. I currently bought the cardone cartridge to replace it. I was thinking i could reuse the housing but that didnt go as planed
