how would you install this/use it.
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
So i'm looking at things because i want "launch control" and i came across this it has
- Smallest Ligthest CDI on the market
- Over 189mJ delivered to the coil per spark, the highest of any other on the market
- Over 500V to the coil primary
- Over 50kV to the coil secondary (assuming a 100:1 coil)
- Intelligent Spark Profiling (ISP) allows for less delay between successive sparks
- Spark Restrike up to 4500 RPM
- Provides this high level of output from as low as 8 Volts from the battery
- Works with any 2 coil OEM ignition, with or without fac ignitor (some systems may require replacement coils)
- Built in launch limiter, works from 2000-11900 RPM
- Built in fixed timing retard function
- Tach output but would it fit my car and if it does how ? i have never seen something like this before. here is the link .
STM: DYNATEK ARC-2 IGNITION | 95-99 DSM
I wouldn't.
I'd take that money and put it towards ECMLink.
Consider the quality of the OEM ignition and the features of ECMLink.
You get far more value for your dollar
Hal
You don't need that with your setup. Keep saving towards DSMlink and when you're close enough then sell the SAFC and put the cash towards it. You can find Eprom ECU's for between $100-$150 shipped. Used complete setups pop up from time to time for less than $500 shipped.
id just find a eprom ecu buy the ostrich 2.0 and tune it with jackal or werewolf and be way ahead of the game both very good programs that hak has developed from another website. just my opinion tho
There was a 1g eeprom on ebay with a starting bid of .99 last week. You can usually find them for under 100$ shipped if your patient.
Or just got look in every 1g you can find a junkyard, you never know. I got my ecu for 22$ plus tax.
The other alternative to tuning is black box. google it up or visit ceddy.us. It's basically like link but the UI is a little more difficult. I managed to have a blackbox in my car when i bought it. Bought a tactrix today for 115 dollars shipped. I got launch control, antilag, fuel maps, knock retard. This is what evo's use to tune with EvoScan. New capabilities of the tactrix is standalone logging. It logs to a micro SD card. Really cool stuff.
:hellyeah: that's nice well ill find out in a week or two if mine is eprom i have a 1995 turbo awd i hope i do !!!
Take your ECU out and check. If nobody else has jacked the ECU out of your 95, then you have one.
Joel
Really ? sweet ! ya there is a long sad story on how i got my car i found it behind a shack for over 4 years of junk on it didn't run or anything so i'm trying to get it to run right and back to life with out "rice" LOL that's why i have a 2.3, got it real cheap i mean dirt cheap but are you sure i'll have a eprom ? what should i get dsm link v3 or v3 light the stm tech guy said light. :confused:
2g ecu in a 1g is easier than a 1g ecu in a 2g because in the 2g the ecu controls things like the fans that are not ecu controlled in the 1g
