how to tell :spun bearing
Terminator2026
45
Sep 2, 2012
lewes, Delaware
Im pulling my oil pan off becuase i have a ticking noise. What should i look for besides glitter, also how wpuld i be able to tell if i had a bent valve? Would i have to remove them?
If the bearing is completely gone or really badly damaged, youll be able to move the end cap/rod SIGNIFICANTLY by hand. You can do a compression test to test for valves in most cases... are you sure its not a normal noise?
Its either a lifter or a spun rod. Its really quiet rigjt now but its there.ill probubly replace the lifters motor has 220,000
^ Good info.
"Ticking" has such a broad meaning when it comes to description. Some people think a knock is a tick, a rattle is a tick and so on....
Is it rpm dependent? Does it increase with rpm? Decrease with rpm? Does it quit at any given point? Does it sound like its coming from a specific area?
Noises can be tricky to diagnose. A "tick" or a "knock" can be a leaky exhaust, lash adjuster, tob, bearing, power steering pump, loose flywheel, ect and sometimes lead people in the wrong direction.
Here is an example of a "knock" noise that I for sure thought was rod knock this past season after beating on the car all weekend at the SO.
[ame]http://m.youtube.com/watch?v=2rrrvm70C_I[/ame]
Myself and many others though it was rod knock for sure, but ended being a loose flywheel banging around on the flywheel bolts. What I'm trying to say here is noises can be decieving and a little more investigating is in order.
With 220k it may be a good idea to take a peak regardless and maybe throw some fresh ones in if they show signs of being past tolerance.
GL
