how to splice wire into ECU question
Funfettie
419
Sep 19, 2011
Menomonie, Wisconsin
So im installing an LC1 wideband into my GSX, and I have never worked with splicing wires into the ECU for data logging. heres what im doing
Brown wire from LC1 to ECU Pin 75 (white)
So, do i cut wire 75 completely and atach it to only my brown wire, or do i cut it, and connect all 3 wires? (2 ends that i cut apart and the wire i need to attach)
Thanks!
Tanner
I always use wire strippers to cut back a price of the wire Casing but not cut the whole wire. Then I use a pick to make a hole in the wire and then insert the spliced wire Into that hole. Twist it around and then heat shrink the wires. A zip tie is good to put over the splice too so it's harder to pull the wire out
    • george bromwell
    • pma1123
    • Sdcryan1
