2G How to properly mount/seal a fuel cell in the trunk of a hatch NHRA safty
TheFlashDSM
Supporting Member
1,106
356
Feb 18, 2010
stony brook, New York
after i mounted my fuel cell in the spare tire well, i then needed to seal it from the drivers compartment, there are 2 way to seal is off, 1. a firewall, or 2. a sealed box on top of the fuel cell with access panel. (as i made in the video)
how to properly seal a fuel cell in a hatch back.
VIDEO----->
---fuel cell mounting---
1. must use minimum of 1/8" thick x 1" straps top and bottom. welded or bolted in
2. must use 1" tubing frame to mount the fuel cell to
3. fuel cell must be mounted below top of the rear tires
4. fuel cell firewall, firewall must be .032 aluminum or .024 steel thickness
5. fuel cell must be sealed off from drivers compartment. firewall or sealed box
6. must use fire resistance caulk to seal all panels mounted. (firewall/fire box/floor panel)
link to 3m caulk i used https://www.homedepot.com/p/3M-10-1...ealant-Caulk-CP-25WB-Plus-CP25WB-10/100166701
1" TUBING FROM FRAME RAIL TO FRAME RAIL
1/8" THICK X 1" STRAP (welded/bolted on to hold fuel cell)
1/8" THICK X 1" HOLDING STRAPS BOLTED TO 1" RAILS
.024 THICK SHEET METAL CUT OUT AND PLACED ON FLOOR AROUND FUEL CELL. (MUST USE FIRE RESISTANCE CAULK TO SEAL FLOOR PANEL/FIREWALL/FIRE BOX) (THE RED STUFF YOU SEE IS 3M FIRE PROOF CAULK FROM HOMEDEPO)
SEALED FIRE TOP BOX WAS MADE TO SEAL OFF FUEL CELL FROM DRIVER COMPARTMENT. (VIDEO ABOVE)
FIRE WALL IN A HATCH FROM ANOTHER VEHICLE
Jesus Christ. That'sa fire waiting to happen. You need to run some rubber around those straps. That's going to vibrate and rub a hole right through those corners.
i have actual put little piece of rubber in the corners after everything was all done!!! but yes thanks for looking out! not necessary tho for nhra safety.....
