gsx_hooptie
- 0
- Feb 28, 2005
Ithaca,
New York
Hey guys,
I've often read about the importance of mating springs with appropriate shocks, but how do we decide what's within the boundaries?
For example, if we're talking about Eibach Prokits with rates of 330/160 (taken from http://www.prostreetonline.com/pso/pages/techtips/showarticle.asp?articleid=8), I'd imagine we're supposed to adjust or revalve shocks to get close to this number. What tollarance do we have to get the right number? I doubt the adjustments on KYBs or Tokicos are accurate enough to be too close. Just as an example, would 300/150 be close enough that you wouldn't notice they were off?
Also, what over/understeer effects could you get from different shock/spring rates?
Also, how far off do spring rates have to be from shock rates before you blow a shock?
Lastly, I searched around for a few minutes and found the stock spring rates in the FAQ, but not the stock shock rates. Is there a site that lists the different shock rates, or if they're adjustable, the range of rates?
Thanks for the help, trying to learn.
