Spring rates
Bohrn
1,247
Apr 28, 2002
Chilliwack,
Well, I can't find a list of spring rates for 1g AWD DSM suspension springs.
factory springs and common upgrage springs, such as ST, Eibach Pro, H&R Sport, Progress etc.
is there such a list somewhere?
I have ST springs in the rear and am going to be swapping them out for H&R Sports.(not OE Sports). See, I have always had an issue with a bit too soft a rear setup. It will bottom too easily when going around a corner that has a dip in it or similar setup. I changed my GR-2's for AGX's and it is better, but I have to have my AGX's set to like 6-8 to make it better, but then its really a bit to harsh and can make the rear end a bit jittery on bumpy roads.
I'm assuming the spring rates on the H&R Sport will be better. And they are new, the ST's in the car are 5+ years old.
thanx
From Prostreetonline's website
DSM Spring Rates
These are spring rates we collected, but can not guarantee their accuracy.
For aftermarket springs, we do not have data on the differences between AWD and FWD.
Rates are in lb/in.
H&R Race Springs (AWD and FWD have the same rate):
Front - 430
Rear - 260
Eibach ProKits:
Front: 330
Rear: 160
Suspension Techniques:
Front: 200
Rear: 160
Stock (Non Turbo/Auto Tranny/Manual Tranny):
OEM Stock 1G FWD
Front: 134
Rear: 128.8
OEM Stock 1G AWD
Front: 146
Rear: 140
95-96 OEM Stock 2G AWD
Front: 265
Rear: 162 (+/- 8)
97-99 OEM Stock 2G AWD
Front: 246
Rear: 151
95-96 OEM Stock 2G FWD
Front: 246
Rear: 173
97-99 OEM Stock 2G FWD
Front: 246
Rear: 151
As far as I know almost anything with GC. I was running 440lb in the front and 375lb in the rear. I just called them and told them what I was going to be doing with the car and they made a suggestion of 400/front 300rear and I said I wanted just a little stiffer, ended up with 440/375.
