2G How to get the most out of my stock t25?
0fg
35
Mar 20, 2010
Grand Junction, Colorado
97 talon tsi. 3" exhaust, no cat, boost and egt gauges, manual boost adjuster.
So, I was messing with boost adjustment today. I did manage to run into fuel cut even though it has the stock t25.
If I change to a different fuel pump and FPR can I then max out(15-16 psi) my t25 boost on stock injectors? Do I need bigger injectors too?
Suggest a nice quiet upgrade fuel pump?
You won't need an afpr for a stock pump, or usually even the 190lph. LIke said above you are pretty much already at the limits you should be able to run 15-16 psi on a stock fuel system with a rewired fuel pump without hitting fuel cut. Right at about 15-16psi you are running out of that turbos effeciency range.
