how to check transmission and t case fluid?
93 Eagle Talon TSi
127
Jul 29, 2012
Toledo, Ohio
i need to check my transmission and transfer case fluid. i dont see a trans dip stick any where unless its hidden somewhere or taken out or im blind. i bought the car a week ago and dont know what all he did to it. and how to check the transfer case fluid i dont see a bolt anywhere to check it but theres a cp type thing with alens bolts holding it down and wondering if thats it.
If it's a manual there isn't a dip stick on the transmission. There is a bolt however where you can remove to check fluid. It's a 17mm bolt on the front of the transmission, mid-left, near the bottom of the coolant overflow bottle. You can use a 1 qt bottle attachment to fill it. The attachement has a tube on it that connects to the bottle. I usually use the pinky rule when I fill a trans. Put fluid in till the tip of your pinky has fluid on it. This helps from over filling the trans. This should help you locate the plugs as well. :hellyeah:
