How much can a HE351VE exhaust housing be clocked?
dsatchell
62
Dec 14, 2010
Austin, Texas
I am thinking about buying an HE351VE but I will need to clock the exhaust housing since my car is RWD. Does anyone know what the limits are?
I keep seeing mention that they can be rotated but that you have to be careful of the oil holes. There are three sections; the center, the compressor, and the turbine. Does the oil or water flow through the compressor or turbine or only the center?
Thankx.
Thankx.
Only the center and the VGT controller motor/gearbox.
There is a small pin you have to remove between the CHRA and the housings and then they can be clocked anywhere as long as the exhaust flange doesn't hit your feed line fittings.
I picked one up and there are definate limitations in clocking both housings. The exhaust housing has major limitations as it has a number of area where the housing interfers with the center section.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
