How do I street tune my 2g gsx with Safc 1??? help
DruSkeez
Aug 6, 2011
Staten island, New York
Can anyone help with a link or charts I need some directions to street tune my 97 eclipse gsx...
I just bought this car its my first dsm
the car has a safc 1 .... I don't want to spend sooo much money on a professional 2..and I would rele like to learn how to tune my car myself with the safc
The safc is disconnected because the previous owner cut the wires from the safc to the ecu
So in other words I need a guide to match up the wires and I need the best numbers to put the safc To..
Car has new 16g turbo the serial numbers are 01420
550 injectors that havent been installed , waiting when ready to do tune ill throw in right befre I tune
Greddy pipping
Greddy bov
Mishimoto intercooler
I need help , any info is greatly appreciated
Thanks alot ill,check it out
In the link it showed stock 2g set up and then a 1g with 16g turbo
Btw,I have a 2g 16g turbo in my car with 550cc injectors
How would I go about setting it best for that set up?
Get a datalogging setup and a wideband too. Otherwise you won't know what to adjust your fuel map to. Fill out your profile too.
I have a 2g 16g turbo in my car with 550cc injectors..How would I go about setting it best for that set up?
We can't tell you how to tune your car. Every car is different, every setup is different. It would be easier trying to diagnose an engine failure over the internet than trying to tune your car for you.
The RRE link posted above shows just a few guidelines about proper tuning with an AFC....here are some more threads on the topic:
http://www.dsmtuners.com/forums/tun...82204-initial-s-afc-settings-high-low-2g.html
http://www.dsmtuners.com/forums/articles-tuning-ecu/366004-safc-tuning-how-why.html
http://www.dsmtuners.com/forums/articles-tuning-ecu/105569-how-safc-works.html
If you follow those steps you should at least be in the ballpark.
