need help with safc 1
hondaslayer1
407
Nov 1, 2009
waukegan, Illinois
Have a safc that I got from a neighbor.the problem is that I tried to test to c if it works and didn't get gower to the screen.took it apart and found the wire clip came off the board inside.I reconnected it and put it back together and tested it again and still no power.now I used the red black and brown wires to try to power it up and no luck.is there something I have done wrong like not putting the yellow wire with the red power wire.need help asap thanks
Im not much of an electrician but I know when installing a car radio you tie the red and yellow together. If you cant fix it bring to a local electrician of some sort, im sure they'll be able to fix it
I know this is off the topic, but why do you want an safc 1.
I have one and i dont like it. I guess it does the job especially for what it cost, but sometimes i'll even knock on race gas.
Ok I tried putting the yellow and red together and have the lights on the safc .now my question is how to get the screen to power up.want to make shure I get power to thw unit before I install it
Ok tryed the yellow wire with red and got power to the. Buttons but not to the screen.how do I get power to the screen want to make shure I get power before I install
