jpmxrider489
- 2,415
- 152
- Apr 4, 2010
pittsburgh,
Pennsylvania
I have just recently upgraded to a twin scroll setup with tial mvs wastegates. When I had a single wastegate, I installed the way my aem truboost directions said to. I believe before I had the turbo port going to the solenoid. Then the other end of the solenoid went to a T and had the side port and top port of the wastegate. I also go to the directions from tial and they say to look at the boost controller instructions.
I read a thread on here where the person was only using the side ports and leaving the top open but cant find any supporting threads that back it up. Maybe I should run them as I did with the single gate but with a extra T? If anyone has any pics or have a diagram of how it should be plumbed.
Here are two pics of the setup how I received it. I was confused because the wastegates are not plumbed the same. I am only running spring pressure for now and will have my controller off but want to set it up as if I were to turn up boost when I get it tuned.
