How do I get this metal retainer clip off to remove the connector on the g sensor on a 95 gsx
randizzle420
263
26
Sep 20, 2009
El Centro, California
Anyone know how to remove the metal clip to get this plug off my g sensor? I don't know if I'm supposed to pull outwards on the top or what to do. The bottom side (first picture) the clip sits deeper in the plug. I bought two metal dental picks to have something to lift up on the metal clip I just don't know where to start to get it off
I've only used a small flatblade screwdriver to push the wire down and over the plastic lock and once it's over the lock you can slide the wire out until it clears the slots in the sides of the connector. It doesn't have to come all the way off just far enough to clear the slots in the sides.
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
