How Can I Tell If I Have An LSD? [Merged 7-8]
candela
3,587
4
May 10, 2002
Austin, Arizona
sorry don't mean to double post, but this should have been here in the first place, doh... QUESTION- how do you tell if there is a rear lsd on the car?:confused:
Ok, here goes first post on this site. I just sold my 2gnt, and bought a 2g gsx, woot woot!! Anyways the rear passanger wheel bearing is stuck on the axle and wont come off. I had this issue with the front ones on my NT. Well i'm just going to buy a used knuckle, bearing and axle, but dont know what will work from what. My car is a 97 eclipse GSX, no ABS. The thing I cant figure out is if it has lsd or not. The only thing I can see on a sticker on the differential is the letters JFB. What cars can I take those parts off of and bolt onto this one??? Thanks in advance
Ohh and its an automatic trans.
Get all four wheels in the air and spin one of the rear tires. If the other rear wheel spins the same direction as the one you're spinning, then you have LSD. If it goes the opposite way, you have a normal open diff.
Any 2g I think that doesnt have abs has LSD, my 96 gsx had LSD no abs
Open up the drivers side door and look there at all those stickers. There will be a sticker saying LSD if your car is equiped with it. I believe the sticker is orange atleast on the 1G's it is.
i have lsd good i find out today i tok it to the auto shop and pay my money $60 so theycan lift the car and confirm that has LSD im proud of this litle expense
OK. So does anyone know if the rear half shafts are the same from the LSD to non LSD rear end?
The shaft only or the axle? We know that it's all different on a 1G and I'm sure at least the inner BJ on a 2G is different since it needs to have two sets of splines.
my 90 has that sticker, and no abs, i hate abs
That's nice. Until 92 you couldn't get the rear LSD and ABS on the car at the same time.
That's the same sticker I have on my 91 GSX and my 92 RT/TT, it was just easier to take a picture of the one on the parts car. I'm pretty sure it's the same sticker on all the cars fitted with the rear LSD regardless of year.
The half shaft. Basically, what needs to be replaced if im going from a non LSD diff to an LSD diff on a 2G with no ABS? Looking to switch out the diff but need to know if I need anything else besides that. Thanks again guys.
The axles (half shafts) are different between the non-LSD diff and the LSD equiped one. you need the axles to go with the diff.
There are threads on doing a 2G swap and you'd be better off looking and asking questions in them since this one is just about how to tell if you have LSD. Here's a few.
http://www.dsmtuners.com/forums/dri...-tsi-awd-98-gsx-awd-parts-interchangable.html
http://www.dsmtuners.com/forums/newbie-forum/259373-drive-axles.html
http://www.dsmtuners.com/forums/newbie-forum/150861-rear-diff-lsd-units-2g-awd.html
jacking the car up and spinning a wheel and looking at the other ones doesn't tell you anything. the driveshaft needs to stay stationary (front wheels on ground, car in gear). someone with an lsd can try this and confirm this for me. there are still spider gears in the rear diff. spinning the wheel by hand isn't enough speed or torque to activate an lsd unless it is maybe helical (them i don't understand fully).
How do you tell the difference..
I have a 97 Automatic Eclipse GSX.. I can take pictures if needed.. I need to know if its lsd or non lsd.. what do I look for?:banghead:
forget the sticker guys geeez ... what if the sticker was removed or whatever... jus dont be lazy.. life the car and spin the wheels.. yaaaaay either you do have it.. or you dont.. LOL have a good day guys
Well I looked underneath the car.. and I couldnt find the sticker.. I guess ill have to spin the wheels.. the orange sticker looks like it was removed on the drivers side.. it has little white "void" sticky part of the sticker left.. so Im not sure if they took it off or.. idk.. guess spinning the wheels is the only option :)
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
