holset oiling question
johnmarines
377
3
Jun 1, 2008
houston, Texas
I have read numorous threads in regards to this but I am still alittle unsure, I just purchased the oil return kit from extrempsi and now I am trying to figuare out what kit I need to run oil to the turbo. I am fixing to install a holset 35 with a bulleyes housing. I currently have a evo16g turbo geting oil from my filter housing. My bs is removed and my oil pressure sits about 60 psi. I am thinking about buying EXTREME PSI : Your #1 Source for In Stock Performance Parts - Turbo Fitting : -4 AN Male to Male
this to screw into the turbo, now what oil line should I buy to be able to connect it to the oil filter housing, or can I buy a hose that is a oil restrictor ?
Which threads have you read if I may ask? -12AN is Holset's MINIMUM requirement for the oil return which needs to be custom made so you are already at risk.
Min 10psi at idle
Max 75psi through the CHRA
First, what is your oil pressure at idle and are your highest rpm you are going to run?
