Hole in Engine
Lagless1012
Nov 14, 2011
Chesterfield, Michigan
Okay so I was basically given a 96 tsi. The previous owner drilled a hole in the engine to remove the balance shaft so i have oil leak. Should I try and save the engine or get a new one?:confused:
Pics or are you just pullin a fast one here why would someone drill a hole in the engine WTF
Reading the posts about the holes in the in the engine, all advice are good ideas ie. junk yard, or replce the part that has that has the holes or catch can. Being a newbie to this site you have to watch out for people scamming you. If you buy something off the classifieds make sure your getting what you paid for. There is know one to help you if someone trys to rip you off. I bought some mitsomoto fans that didn't work and a tail 38 mm wastegate which was a knock off and he does not not return any of the emails or texts. This fourm is an amazing resource but watch what you buy and some the advice is sound before turning up the boost or drilling holes into the motor.
I wonder if it is not the factory drilled holes for the oil passage for the front balance shaft.
The ones that are pluged with the small phillips head screws. Maybe the scews are missing. We may never know if the op don't post some pics.
Wow Who would Drill a Hole in their block. WTF!!, I would Tap it and plug it with a Bolt Depending on the location.
