HKS Camshafts
MattRon
Jun 26, 2005
Roxbury, New Jersey
hey would anyone be able to tell me the specifications of the HKS 264 intake camshaft and the HKS 272 exhaust camshaftfor a 1g talon TSi? even better if you know the best advance/retard setup for those cams let me know...im stuck as of right now and i need to get this car together in less then a week cuz thats how long i have my mister 2 for....thanks guys
here is some cam timing info you may be interested in
Advancing Intake and Exhaust : This will provide the car with more bottom end power, and will decrease top end. Advancing both cam gears will move overlap earlier but will not increase it.
Retarding Intake and Exhaust : This will increase the cars top end, but will decrease low end. Retarding both cam gears will move the overlap later and but will not change the amount of overlap.
Advance Exhaust Only : This will help the cars top end, and it reduces overlap.
Retard Exhaust only : This will help the cars mid range power, very useful for cars with big turbos / big cams. By increasing overlap, It decreases lag significantly. Doing this will bring the boost on all at once. Very common DSM modification.
Advance Intake only : This will increase overlap and helps the cars bottom end and mid range power. This mod will bring the turbo on all at once, although isnt a very common mod for dsms.
but this is with adj cam gears
http://www.automotosports.com/cam_test.asp
cam test that AMS posted.
