Hissing sound turning engine by hand
thejollyrancher
307
13
Mar 31, 2012
calgary, AB, Canada
Hey,
Just rebuilt by engine. I replaced all the bearings and piston rings along with a head build. I have yet to throw the cams on there and do timing. I have the bolted down on he block with sparkplugs installed and when im rotating the engine by hand im getting a loud hissing and it gets pretty diffifult to rotate. Sounds like its building some compression. Is this normal?
Thanks
Edit: forgot to add tge bad part. The valves are hissing a tiny bit at the top of the stroke
