Hissing by the firewall?? AIR?
Gary 420A RS
1,188
9
Jul 7, 2003
Oxnard, Ventura, California
behind the the engine by the firewall. i hear a hissing sound like constand air leaking somewhere. i have no idea where it is i checked all the lines i could find then nothing. its sounding as its coming from under the fuel rail.. if anyone would have any idea what it is let me know.. ill post up a video of it later.
Check for a torn lower injector seal. These often make whistling or hissing sounds when they don't seal properly anymore. Running a boost leak test would be a great idea in addition to checking all of your vacuum lines (just to be safe).
Let us know what you find,
Andy
and yesur! it was an injector seal. second one from the left was not seated so i loosened the fuel rail and made sure all of them were in while i tightened it down. i used a flat head to push the seal in place.
NO MORE HISSING!!
  • Wanted 6 bolt NT water pipe
    • chrisman287
