upper air intake removal
Just take the feed and return lines off from each side of the fuel rail and unclip the injectors.
If you're taking the head off dont waste your time trying to get the intake manifold off inside the car, pull them together.
exactly but make sure you just replace the injector seals and o-rings cause they leak...i just fixed a 2g w/ a 20g today that had a boost leak from cylinder #4 injector seals/o-rings ..speak of the devil :rolleyes:
  • Wanted 6 bolt NT water pipe
    • chrisman287
