[RESOLVED] Upper air intake mani torque specs
The smaller M8 are torqued to 11-14 ft.lbs. The bigger M10 are torqued to 22-30 ft.lbs.
make sure you don't use RTV and copper spray is optional, and make sure the red outlined part of the gasket is facing in the right direction. make sure to use some gas and brake cleaner to wash that baby out while its off and tighten everything after you go around it once....just extras i found to be helpful over the years;) and ditch the manifold stay bracket in the back it just extra weight
