hissing near intake and exhaust leak on manifold
dope96clipse
137
Oct 8, 2003
N.P., California
ok i just had a problem with my intake valves ticking and i sorta solved that i got them to quiet down by changing the oil an other fluids, but now i can hear this hissing noise like air going through one of the gaskets or passed one of the injectors, near the intake manifold, could this and the exhaust gasket leaking cause my car to run lean, and make the valves tick like it is, i can smell the exhaust an it smells like its lean idont know how to explain how it smells though. the ticking started the other nite when i was on the freeway i dont know nething of how it was caused and i was wondering if neone had an idea wut the hissing could be and if the stuff listed above would make my car run the way it is thanks..
The valves ticking or the lifters? The only time I've ever heard valves tick is when they were hitting the pistons. Haha. Do you have a logger that you can see if your car is throwing any codes. My mother's car just had a problem of throwing "lean" codes throughout the car and it ended up being a bad intake manifold gasket. You may want to get that fixed, otherwise your going to burn an exhaust valve and have to replace the head/valves from running too lean.
no i dont have a logger or nething, and i think its prolly the lifters, i havent driven the car simce friday when this started, its idled after werkin on it an gone around the block thats it, but i just drove it an i realized, that after high rpms the car bogs down below 500 and then feels like its gunna die an goes back to 900 steady does this help?
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
