Boost Leaks near Intake Manifold
missionx96x
136
Jan 30, 2006
Jackson, New Jersey
OK I clearly have some boost leaks and I found a few of them. Idle screw and AFPR both leaking, both now fixed. Injectors are good no leaks but I still think I hear a little bit of air coming from the intake manifold area. All the hoses are brand new and TB ports are capped on top. Do you think it has to be the Intake Mani gasket? Also the TB gaskets are good I just redid them.
Easy way to check would be to let the car cool down and spray all around the gasket with soapy water and start the car up and see if it bubbles. Gonna have to do it quick before it starts to warm up and bubble the soapy water from boiling it.
^^Good way. Or if you have a boost leak tester you could pressurize your intake and use the soapy water. Shouldn't be too hard to trace.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
