nightspeed87
- 1,761
- 12
- May 2, 2006
Tampa,
Florida
Can somebody link me to some performance ( preferably forged ) and higher compression pistons for the 1g that dont cost an arm and a leg, with rings too?I was considering getting the 2g pistons but dont feel like going through the fabrication to the rods work, I just want something higher compression than the stock 1g pistons ones that will be a direct fit to stock rods with no extra work needed, and I considered putting n/t pistons and just getting them machined down to a lower compression or something but i dont know if anyone has done that, or if its possible, because n/t pistons would be too high of comp for the compression im trying to run, i want something close to the evos or 2gs compression ratio but something that is made to fit in the stock 1g cylender walls with no mod to the rods or boreing out... Thanks.
( Dont plan to ever run over 22lbs of boost )
