Higher Compression Pistons
INDY92GSX
Aug 15, 2002
Indianapolis, Indiana
I am rebuilding a 1992 6 bolt engine for my gsx. I want to increase the compression ratio and was wondering if the pistons from a N/T 2.0 are higher comperssion and will they fit into my engine? Any help would be greatly appreciated.
n/t pistons probably wouldnt be a good idea. You can get forged pistons in almost any compression ratio. If you want to save some cash check out 2g turbo pistons, they have about half a point more compression.
N/T pistons will be way too high for you. I wouldn't go over 9:1 compression pistons in a street car. Find a set of 2g pistons (8.5:1) for cheap, or get a good set of forged ones in whatever CR you like.
Most companies cheap out when it comes to materials and thicknesses for N/T applications because they don't see the same stress that boosted parts do.
Go forged or use 2G turbo pistons if you'd like more compression.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
