93RS
- 140
- 2
- Oct 3, 2011
Brandon,
South Dakota
Hey guys I just did my tb shaft seals..... Along with a thermostat, valve cover gasket, upper radiator hose, oil change and coolant change..... Also regapped the plugs to .028. The only "mod" done to it is the bcs restrictor removed. Anyway when I was doing the shaft seals I stripped the butterfly screws so replaced with smaller bolts... So after I got her all put bak together I did a BLT and I can't find any external leaks but it sounds like its flowing into the intake and therefore not holding pressure.... I took it out for a drive, it idle surges and it allthe sudden its pushes 14psi of boost I'm not sure if to be excited or scared.... I guess in thinking about it it seems to go to like 15 lbs then down to 14.... HELP!!!!
is driving and/or boosting going to hurt the car? And would a mbc stop the spiking?
