Higher boost after tb shaft seals
Don't use the boost pro tester. I'm not a fan of their design at all. After 20psi the tester will begin to pop out of the coupler due to no seating grooves unless they redid their design.
Mine holds 25lbs no problems. Must be magic or something..
The bolts are the same size..... They are tight, I think they might let a little air by just because the heads are smaller. The threads are exactly the same. And I haven't ran into any issues with my home depot boost leak tester.
