high rpm in idle
95dsmgst
Mar 19, 2006
miami, Florida
ok im having a problem. im sure its not that serious. but anyways im having high rpm in idle. 2K ive adjusted the throttle i moved the throttle cable. dont really know. i had fixed it once before. but now after i rebuilt the motor its high agian. i dont know if its becuase a lighter flywheel. 8lbs and i have a bigger turbo. ported head new valves. tubular exhuast mani. dont know can anyone help?
Make sure your throttle plate is closing completely. Loosen the throttle cable and move it as far foward as you can, and see if that fixes your idle. Your BISS might also need adjusted, like stated.
check for vacuum leaks. Do a boost leak test. Throttle body gaskets are bad to leak which will cause high idle. look for vacuum hoses that might have cuts or rips in them. another thing could be your injector seals. A boost leak test will find any of these.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
