super high RPM idle
dsmatt
Feb 21, 2006
Tucson, Arizona
I just put a new head on my car after it was out for quite some time. (bent valves)
i started it up and it seemed rough for a second or two then rose quickly to 3000rpm and stayed there. the car runs/drives fine despite the super high idle. I am assuming the idle is why my CEL is on. Thank you
I forgot....shit. You need a 1g datalogger. Try finding a person local to you on here who has a datalogger.
I ran a few tests of my own and found that i had a huge vacuum leak where my throttle body meets the intake. i threw on a new gasket, tightened it up and it lowered the idle pretty good. Now all i have to do is tune cam angle timing and the TB adjustment screw. thanks for you time and help:thumb:
i am having somewhat the same problem but i thought it was the EGR valve... i had not fixed it yet.... i yanked the egr valve off and its still good.... do u think the same thing that happend to ## car and is happening to mine... i have a 97 eclipse 420A... and it started doing it right after i had fixed a broken header
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
