pasths
- 33
- 0
- Aug 1, 2002
Alright half the time my idle is at the appropriate 750 RPM, but the other half can be between 1000-1400 RPM and holds steady no surging.
What I have found when the idle is high I can pop the hood and play with the accelerater cable(not sure what its really called but you can accelerate the engine with it) behind the throttle body then the idle goes down. Its as if the "butterfly" is stuck so I cleaned the intake manifold but that didnt fix it.
Could it be the accelerator cable with the spring attached to the throttle body?(I've tried spraying it down with wd40)
Do I need to replace the whole cable maybe? If so is the spring a B-TCH?
Thanks
97 Talon TSI FWD
Thanks
97 Talon TSI FWD
