2G high jumpy idle and cel P1105
mheidemanjr
203
Jun 7, 2009
medina, New York
before you b#%ch at me i searched first but no one had the exact same situation so a new thread is born!
when i first start the car the idle is at 1k rpms after i get it going down the road and push in the clutch it will stay at 2 k for a min then drop to like 1500 and the to 1200 and stay there, that's to high right? any ideas what could be causing this?
i did a boost leak check today and its all good no leaks held 15psi for about 2min before dropping to 1 or 2 and i could not hear nothing also the cel is on throwing code p1105 for the fuel pressure solenoid. i tested it by hooking power and ground to the solenoid and it open and closes so is it still good or do i have to do a resistance test?
any input would be great thanx!
i forgot the isc voltages off hand by tps should be .63 volts i believe.
You take off the connector on the tps and isc respectively and using a volt meter check a certain combination of the pins. Search for it and you will find you answer.
