High idle then engine stall, stumped.
bomper04
256
Jan 21, 2008
Berkeley, California
Recently rebuilt my cylinder head due to bent valves, changed out guides, seals and valves. Cranks over and starts but results in a super high idle around 3k then slowly drops back down, stumbles (misfires) then dies. I can rev freely over 3k but once i let go of the throttle, it dies. Possible IAC problem? Cleaned out IAC and changed gasket. Still the same problem. Any guesses?
IAC is okay, resistance tested and checked out to spec. Moves with key on. TPS okay as well, did a voltage sweep and measured just fine. Any ideas? Starts then immediately jumps to about 3k-3500RPM then drops down to about 750 followed by stall. No CELs.
Can you keep it running around 2k rpms by pressing on the gas? If so, do that and see if a light will kick on eventually. Check your MAF while you are at it.
MAF is plugged in, kept the car running with foot on gas pedal and no light. It's OBD1 so I can't imagine it to be too intelligent LOL. Even switched out IAC with a known good one and same symptoms.
