High flow cat
iggster
30
Feb 1, 2005
Janesville, Wisconsin
Ok all. Here is the scenario. I just recently replaced my entire exhaust sustem with new stock exhaust parts. Yesterday I went and picked up a hiflow cat. IF I use this in place of the stock cat keeping the stock muffler on will I still see performance gains or should I now replace the stock muffler as well?
Why didnt you just buy a bigger aftermarket exhausy system with a test pipe that would give you the best results. But since you didnt maybe the stocker you got was really cheap or something but i suppose the high flow cat will help a little but not enough for you to notice.
Let me refresh here. They were Mopar replacement stock equivalent. I work for a dealership. I was originally just going for stock but now have gotten the bug and want to increase performance. I guess the DSM bug has just bitten me now! :p Not looking to totally redo engine or anything but little things. So in from what I am hearing I should also upgrade the muffler to make the most use out of the hi flow then? If so does anyone know of any good ones that will come with the flange or should I just plan on doing some welding?
What your going to want to do is buy a system or have one custom made at a exahust shop wich will be cheaper. You will want to get a bigger downpipe 2 1/2 or 3 and then a cat back system to match either 2 1/2 or 3 inches. Basicly your going to replace all of the exhaust pipes with bigger ones with less bends in them. As far as what ones to recomend just do a search and you will find many threds on them from videos and sound clips to peoples opinons on them.
listen to this guy. You can change your cat and muffler all you want for maybe 2hp, it's the restrictive pipes that are the problem. I know you probly weren't trying to spend that much money but thats the blunt truth of it.
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
