twicks69
Supporting Vendor
- 4,333
- 2,073
- Mar 12, 2004
Milwaukee,
Wisconsin
Kelvin, the early 3/4 synchro you need is MD744782. It will work with 1990-1992.5 gears.
As well, on a side note, you were discussing using your 1990 FWD gears, be sure you use a matching intermediate shaft, output pinion shaft, 3rd and 4th gearset, and front diff ring gear. The profiles are a matched set for those parts. You can use the later year input shaft and 1st/2nd gears, and 5th gearset if you want with these other components. If you are going to use the 90-92.5 gearsets then you need to have the matching 3/4 shift rail and 3/4 shift fork to have the right roll pin orientation.
