Need help with rebuild part numbers
turtleb00st
108
32
Jun 18, 2012
orlando, Florida
So, hopefully a guru can help me out. I’m re building a 5spd 1g awd tranny. I need help with these part numbers
1. I had to ez out the flushed tapered screw on the reverse assembly. I called jacks who pressed my new gear stacks together and they don’t stock the screw or have a p/n
2. I also need the part number for the needle bearing that sits at the end Input shaft inside of 5th gear and the synchro.
3. Small output shaft bearing.
All help is very much appreciated.
Just shoot me an email at [email protected]
As for the small output shaft bearing, are you referring to the outer output pinion tapered roller bearing or the output shaft needle bearing? The needle bearing is discontinued.
I have the machine screw new. OEM or aftermarket or if you want the dimensions, no problem.
I have the 5th needle bearing in stock.
Or if you want just the part numbers that's fine too.
