ECMlink Help with SD tune
CDgr97GSX
162
10
Feb 11, 2009
Romania, Europe
I need some help to tune my car on SD. I'm trying for few days to get my idle tuned but no success so far. I have all the sensors installed and logged to EcmLink. The problem is that i can't get a good idle even if i get my combinedFT close to 0 and the airflowperrev to 0.25. Today i tried to use narrowband simulation...and thing went even worst...the car is not idle at all. I couldn't do it till now because i couldn't get voltage from AEM WB to log...i just found the problem was the gauge socket...it was no contact between gauge pin and the wire. I took the AEM sensor from rear to front...made all the settings...but nothing. I tried with my AEM WB set to P04...then with P02...with or without narrowband on...log in front O2 then in rear O2...same result. I got tired and just leave it for today like it is. Here are some logs from few days ago.
Can someone have a look at some logs from my last tune...just to see if i'm going in the right direction. I manage to set the narrowband sim with the AEM sensor in front and set to P0.
try this http://www.google.com/url?sa=t&rct=...hbn9wbcFw1zB7QO_Q&sig2=nYeFAwNsODzBUfxRu665uQ
link is not working try global fuel -72 & in direct access inj battery adj 7v2295 9v1350 12v865 14v685 16v595 19v495 global dead time 0 that should help go for drive & run sd ve combined ft
I did try to change the global fuel with some values other users from here are using but didn't help much...and also when i use injbatteryadj with other values then stock...it doesn't seems to help...i also tried the values i have for my injectors from the FIC testing paper sheet...same result. Anyway...i will try your suggestion and see if is any improvement.
Ok I run in 2.3 & my setting are much higher my global fuel is -69.1 & my idle is not that good either but I do not expect it to be this is a very big injector, try thouse settings and post back log
Here is a log with my idle and a little cruising after i did the changes you suggested. About the idle and the injectors i can say that before i bought them they supposed to be the best one for a idle like stock
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
