help with new log please
Silver99GSX
225
Feb 18, 2008
Schenectady, New York
hey guys i wanted to post a log of a run i did today. I just got my ltft's somewhat in order and did a run with timing flat across the board and some fuel added in the higher rpm's. im running 25psi on 93 oct. i guess my question is "just tring to get some opnions" shoud i try to add more fuel or reduce timing to clean up some of that knock. Thanks
I assume you're doing all this tuning without a wideband?
Also, why are you adding so much fuel?? Are you on stock injectors (according to profile you are, but according to link you have 880's)? You should never need to add fuel, especially running 880's.
I'm not sure if there's something wrong with the log, but I can't access a good bit of the ECU screens.
