data log help please
speedy_talon28
364
3
Apr 1, 2006
elkhart, Indiana
Does this look ok
RPM: 1562
TPS: 19.9%
TIMA: 37 degrees
INJD: 3.1%
EGRT: -28.2 C
FTRM: 100.0%
FTRH: 100.0%
FTO2: 167.1%
Do you mean this or a graph for each one ???
RPM: 1562
TPS: 19.9%
TIMA: 37 degrees
INJP: 2.81ms
INJD: 3.1%
EGRT: -28.2 C
FTRM: 100.0%
FTRH: 100.0%
FTO2: 167.1%
O2: 0.07
cool: 96.8 C
AIRT: 49.1
BATT 10.7 V
MAFS: 56.6 Hz
Do you have a specific driveability problem? Are you trying to tune your AFC? What are you trying to show us?
You need to post a log throughout the rpm band,not just a snapshot of that rpm your at.You also need to post your low fuel trim,and your battery/alternator is bad since you only have 10.7 volts.Your mid and highs look fine,100% is perfect.Your o2 trim will bounce around with driving and its normal,with your log,it's at 167% which means your accelerating and the car is adding fuel to make you accelerate.With your low,mid,and high trims,<100% is rich,>100% is lean.On your o2 trims,its the opposite.
