help with awd 1g build
SVT2DSM
46
Jun 23, 2011
blacksburg, South Carolina
Mods so far:
-Stage 4 act 6 puck clutch
-balance shaft delete
-cyclone intake
-560 cc injectors
-255 fuel pump
-rebuilt 14b turbo (running 20lbs)
-fmic
-3 inch exhaust
-8mm spark plug wires
-ngk spark plugs
-hks 272 cam
-brain crower valve springs
-brian crower valves
-adjustable cam gears
-larger intake piping
I'm aiming for around 400hp. Will that get me there? If not what should I do/get?
Oh yeah and a "rams horn" style exhaust manifold
That 14b won't cut it. I'd go 50 trim or bigger for 400hp. Also you will need larger injectors than 560cc. Probably no less than 800cc or so.
Go with a bigger turbo, t3/t4 maybe. And they also spool pretty low for the size. Bigger injectors, afpr, DSM link will help as well. Also maybe an inline 2.5 or 3 in gm maf.
NO NOT WITHOUT A STANDALONE ECU (AEM EMS) OR DSMLINK(cheaper).If your car is actually running right now it makes me think you must have some sort of ecu upgrade though? bigger injectors, 600-700cc and you dont need a 50trim thats pretty big, i would get a 20G.
Also if you have the stock tranny i would recommend a rebuild from shepracing.
Your best bet would be to get dsmlink and a wb to tune all those mods are worthless without it, Then i would worry about upgrading the turbo, 20g is perfect for a streetable 400hp. And im sure youve heard it before you cant just throw parts at a car and expect 400hp everything has to work together correctly with a good tune on top of it.
