Help! What's wrong with my car?!
nighthawk355x
49
Oct 27, 2005
Edison, New Jersey
I made the mistake of beating my car today and as always...PROBLEMS! Everything was great, boosting fine, then, all of a sudden, the car started lagging like hell. It basically wouldn't rev past 2000 rpm in any gear without stuttering like it was going to backfire. The car wasn't smoking at all, and when the engine's running it sounds fairly normal, no knocks, ticks, anything, but the rpms are jumpy.
The few things I did notice...
-when I opened the hood the manifold was GLOWING it was so hot
-don't hear the turbo at all anymore(i can usaually hear something faint at least, even at 2k)
-when you let off the rpm's drop to around 500 and bounce back and forth a bit(when it was hot)
-after it cooled and I started it the motor kicked over fine and again sounded fairly normal but then shut off almost immediately(it starts, hits idle and then drops off and stalls)
Car has an evo 16g, ported manifold, stock downpipe, aftermarket rear 1/3 exhaust, fmic, and nothing else(if it helps)
sounds like you blew a coupler off the charge piping. just my input. happened to me a couple times a few months ago. exact same symptoms.
Ya me too it sounds like the ic piping, also if you blew a spark plug wire for me it would not boost hardly at all and sometimes it would jump around and boost fine for a second.
I had a prob like this the other day, and my car wanted to backfire and it wasnt acellerating correctly- it was my msd coil pack not making the number 1 spark plug work. Just giving you another idea - You possibly have a boost leak? My buddies rx-7 was doing this as well, and he had a leak- Hope you find it!
it's a little different though with an n/t that has had a turbo added. correct me if i'm wrong, but you're still on a map sensor. the gst/gsx maf sensor is placed before the turbo. this means it's metering air that the turbo is taking in, and calibrating the fuel and timing maps for that air. then with a blown coupler, there's a huge boost leak. all the metered air just went bye bye, so suddenly there's this extra fuel and timing with no use. not good. kinda the same principle as why you install a plumb back bov on a gst/gsx, so you don't lose metered air.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
