2G Help Selecting Brake Upgrade
yellowkyd278
124
Sep 28, 2004
Los Angeles, California
I'm trying to find how deep I need to go in brake upgrades for my applications. I drive a 2.4 evo16g making the usual 330 - 370 whp (dynojet)... maybe a bit more but you get the idea.
The car is primarily a daily driver seeing -- 85% of it's life is on the roads. I auto-x occasionally but by no means do it competitively. A majority of the other 15% is spent on open track days. I usually go about once a month -- sometimes 2 -- but usually once.
So do I:
1. Just get a set of good pads (R4-S, R4-E, R4)
2. Add a pair of front rotors too (powerslot, stoptech) to the pads
3. Get a $500 - $700 front brake kit (stage-2 stoptech, baer, powerslot)
4. Get a Wilwood front kit from TCE (13.0" dia x 1.10 or 1.25") for $1400
5. Go all out and get the stoptech big brake kit for $1900
6. There's a deal for a pair of Wilwood 4 piston Aluminum calipers w/ race pads from TCE (12.2" dia x 1.25" 2 piece aluminum hat safety wired rotors) $600
From what I'm reading changing the rears aren't a necessity...
Anyhoo, any input or suggestions are appreciated. Thanks!
A. Do NOT get a drilled rotor for open tracking.
B. Use only a RACE pad (preferably matched compounds to start off), front and rear, for open tracking.
C. Some guys (GreenGSX) are using SS lines/race pads/cooling ducts/stock 2pot brakes, with good results.
D. Others (Slow Old Poop) break 1.1" x 13" rotors like changing socks.
E. The track you are running, and your driving style determine what will really work.
F. I tend to like to err on the side of WAY too much brake, therefore...
I like your option # 4 if $$ isn't tight, or #6 looks like a SMOKING deal. Todd's (TCE) kits and customer service are awesome too.
i'd go for #6. i know the set you're talking about, the guy seems legit i was talking to him about them as well.
As weird as it may sound, could always do the latest. Install Evo rotors calipers etc onto your gsx.
I purchased a pair of drilled & slotted TPM rotors, why shouldn't I use them? Because they weren't cheap!
Under open track situations, drilled rotors have a greater chance of cracking around the holes. Doesn't always happen, it's just that non-drilled ones don't have holes to crack around.
I've never heard of Hawk greens, are they new?
JFZERO, are you talking abuot the JDM Galant spindle/EVO VIII caliper swap? That setup is sweet. :cool:
Yeah, he's talking about the JDM Galant knuckles / evo8 switcheroo.
Anyhoo, any more suggestions? List is on first post
Andrew
Andrew
  • Wanted 6 bolt NT water pipe
    • chrisman287
