1G Brake Upgrade
Xero_Tolerance
145
Sep 27, 2002
Austin, Texas
Hey everyone, I have a 92 gsx, so I have the small brakes and I definitely need bigger ones. Now what I want to do is get some after market slotted or drilled brakes but I also want to do the upgrade to the bigger style vr4/3kgt(n/t) brakes. I'll probably be upgrading the pads and lines at the same time too. So what exactly would I need to buy other than the rotors, pads and lines in order to do the big brake swap? Thanks.
You are going to need the calipers, pads, rotors, and the caliper brackets. From what i understand, the caliper brackets are not available seperately. I just got my setup off of a 95 diamante from the local wrecking yard. $40 total for all except the pads.
Does the Diamante have the same calipers as the AWD 93+ or the 3000GT n/t?
I'm looking to upgrade my FWD
3kgt sl and 93^ awd has the same calipers and rotors. I think the early 95 had a differant caliper that used a banjo fitting so If thats what you end up with, you need the brake lines also.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
