HELP - pointy transmission bolt
TheRealMRDyno
46
5
Aug 19, 2009
Akron, Ohio
Hi,
Who knows where the pointy transmission to engine mount bolt goes?
I have 4 main bolts, plus 2 for the metal gasket.
Two on top are same size, and *close* on length, but one is pointy and longer.
Where does it go?
I searched, closes I could come was a CAPS picture, looks like 20999Y and 20999U.
Thanks!
The longer one that is the same diameter as the two shorter ones goes right by the slave cylinder. The longer, skinnier one, which isn't pointy but normal looking, goes right above the driver side axle, where it enters the trans.
Thanks, but I am asking about the pointy bolt.
Long big = front
Long skinny = rear
But, 2 short bolts on top - one is pointy, one is not.
Where does the pointy one go?
