6 bolt transmission shield question. HELP!
wadebyers
Oct 27, 2009
indianola, Iowa
So I am in the process of putting a 6 bolt into my original 7 bolt 1g. Everything has been going great so far but need help determining what bolt size holds it to the bottom of the block, there are 2 of them. The bolt that goes into the tranny is the correct size. I want to just hit the hardware store on the way home from work rather than going and digging through the bolt bucket to see what fits. If I cannot figure this out I will use the bottom bolt that goes into the tranny and black silicone it to the bottom of the block, ideally I would not want to do this. Thanks in advance.
BTW: its a awd 5-speed if needed
