6 bolt swap-transmission ?
matta
105
5
Aug 20, 2012
Gilbert, South Carolina
I have a 6 bolt engine and a W5m332npzs transmission. I ran the numbers and it turns out to be a trans from a 90 GSX? That wouldn't work with my 2g driveshaft or rearend would it. also, where are the numbers on the transfer case?
It isn't that simple. 2g transmission has mounts on it. The 1g transmission does not have provisions for front and rear mounts so it is not a bolt in. Gear ratio changes didn't happen until 1997 and you did not mention what year 2g you have. I"m assuming is isn't the 2g NT picture.
Just noticed you have 4 posts and only list a 2g NT in your profile. If a swap is your intention my opinion is do not try this. I will make no more mention of this. It's an argument that has been going on since 1995. The answer was the same back then also.
Can anyone tell me if I need the 95-96 GSX transmission or the 97-99? Again, this is going in a 96 GSX. I counted 25 splines on the shaft that is bolted on the 6 bolt motor I have
