ECMlink (help) nitrous setup with ecmlink v3 full
This is the cause. ECU will be grounded to activate/trigger a relay. Not to send a power.
How would you wire up the relay? Ecu output to 86, switched power to 85, ground 30 and 87 to the nitrous solenoid?
No, it won't work like that. You have no power supply to the solenoid.
For instance :
Relay 86 - ECU
Relay 30 and 85 - Switched Power
Relay 87 - Nitrous solenoid positive
Nitrous solenoid negative - Ground
For instance :
Relay 86 - ECU
Ahhh ok, so that was the issue, I needed 30 to be powered too. Thank you very much. Can't wait to try it later
