ohlegend
- 581
- 43
- Apr 2, 2012
Pemberville,
Ohio
I have a 7 bolt from a 98 GST that I am rebuilding
I took time and cleaned and repainted every part.
I have almost all of the sensors, but I don't think Im going to include them...just in case.
I have 850$ in new parts into this rebuild
I was thinking 1500$?
7 Bolt block - Bored .02 over and resurfaced
freshly resurfaced crankshaft
SCAT H-beam forged rods with ARP hardware
.02 over ITM pistons with new ITM rings
New water pump & gasket
LG Waterpipe that runs to head
New ACL front case/oil pump & gasket
New ACL main bearings
New ACL rod bearings
New ACL thrust bearings
New ARP headstuds
Balance shaft elimination kit
New rear main seal/gasket
MLS headgasket
New oil filter housing OEM gasket
"z" coolant pipe that runs from OFH to turbo
Head
8 new valves, 8 old valves - all are seated correctly (air tight)
new supertech valve seals
4 new lifters
All new gaskets
uncracked valve cover
Intake manifold and exhaust manifold
new timing belt
All the rest is stock
EGR block off plate
Stock cleaned throttle
Throttle body elbow
Cam angle sensor housing
Fuel rail with spacers, inlet flange, and fpr
Thermostat housing
New ARP headstuds
MLS headgasket
Head
4 new lifters
All new gaskets
new timing belt
EGR block off plate
Throttle body elbow
Thermostat housing
